Displays LACP, or dynamic link aggregation, settings for the specified port that is a member of any LAG.
port |
Specifies the port number. |
detail |
Show detailed information. |
N/A.
Member Port.
Port Priority.
Idle.
Initialized.
Current—Receiving LACP PDUs.
Expired.
Defaulted.
Selected—Ports with a matching admin key on the remote end.
Unselected—Ports that failed to meet with a matching admin key on the remote end.
Standby—Ports that exceed the number of ports that can be active in the LAG simultaneously. These ports can be moved into selected mode if one of the currently selected ports in the LAG goes down.
Waiting—Selected port that is waiting for LACP to determine if it can join the aggregator.
Attached—Ports ready to be added to the aggregator.
Collecting-Dist—Ports that are added to the aggregator and are transferring data.
Detached—Ports that cannot be added to the aggregator.
A—Activity.
T—Timeout.
G—Aggregation.
S—Synchronization.
C—Collecting.
D—Distributing.
F—Defaulted.
E—Expired.
The operational value of the port number assigned to this link by partner.
Up or Down—LACP protocol running or not on specified port.
Enabled or disabled (not configurable).
Link State—Link state on this port up or down.
Actor Churn—True or false.
Partner Churn—True or false.
Ready_N—Ready to be added to aggregator.
Wait pending.
Ack pending.
S—Displays information on controlling partner of LAG.
T—Displays information on controlled partner of LAG.
Rx - Accepted.
Rx - Dropped due to error in verifying PDU.
Rx - Dropped due to LACP not being up on this port.
Rx - Dropped due to matching own MAC.
Tx - Sent Successfully.
Tx - Transmit error.
The following command displays LACP information on the specified port:
show lacp member-port 4:9
The following is sample output from this command on a switch:
Member Port Rx Sel Mux Actor Partner Port Priority State Logic State Flags Port -------------------------------------------------------------------------------- 4:9 300 Current Selected Collect-Dist A-GSCD-- 4009 ================================================================================ Actor Flags: A-Activity, T-Timeout, G-Aggregation, S-Synchronization C-Collecting, D-Distributing, F-Defaulted, E-Expired
The following command displays detailed LACP information on the specified port:
show lacp member-port 4:9 detail
Member Port Rx Sel Mux Actor Partner Port Priority State Logic State Flags Port -------------------------------------------------------------------------------- 4:9 300 Current Selected Collect-Dist A-GSCD-- 4009 Up : Yes Enabled : Yes Link State : Up Actor Churn : False Partner Churn : False Ready_N : Yes Wait pending : No Ack pending : No LAG Id: S.pri:2110, S.id:00:01:30:f9:9c:30, K:0x0fa9, P.pri:300 , P.num:4009 T.pri:2110, T.id:00:04:96:10:33:60, L:0x0fa9, Q.pri:300 , Q.num:4009 Stats: Rx - Accepted : 2174 Rx - Dropped due to error in verifying PDU : 0 Rx - Dropped due to LACP not being up on this port : 0 Rx - Dropped due to matching own MAC : 0 Tx - Sent successfully : 2175 Tx - Transmit error : 0 ================================================================================ Actor Flags: A-Activity, T-Timeout, G-Aggregation, S-Synchronization C-Collecting, D-Distributing, F-Defaulted, E-Expired
This command was first available in ExtremeXOS 11.3.
